SweepMe! 1.5.6.29 released
Greetings, SweepMe! users,
We are pleased to announce the latest improvements and fixes in SweepMe! 1.5.6.28 and 1.5.6.29, which enhance the overall functionality and user experience of the software.
Changes since SweepMe! 1.5.6.27:
  • Export/Import: A new feature has been added to export and import drivers, modules, custom function scripts, and various configuration files. This allows users to easily transfer their setup between different installations or share them with others.
  • Backward compatibility: The new version supports loading settings created with the upcoming SweepMe! 1.5.7, ensuring users can work with the latest settings even when using older versions.
  • Example settings: Example settings using Add-on modules have been added, allowing users to learn how to use the software more effectively and efficiently.
  • Automatic path addition: Library folders of drivers are now automatically added to the system path before loading. This ensures that the required libraries are always available and driver authors do not need to add them manually.
  • Driver update: The pre-installed SMU-Simulation_Diode driver has been updated, improving its functionality.
  • Stop and Pause functions: The Stop and Pause functions have been improved to immediately halt measurements and update the GUI afterward. This mainly affects programmatic calls to those functions from within the measurement itself.
  • Variable availability: Variables of modules are now completely read before the first measurement point is taken. This ensures that all necessary data is available before starting the measurement, allowing the use of these variables as parameters.
  • Module compatibility: The new version fixes an issue that prevented SweepMe! from starting when encountering incompatible modules from SweepMe! 1.5.7. When using SweepMe! 1.5.6 and 1.5.7 in parallel, this update will be essential.
For a complete version history refer to the changelog on the SweepMe! website.
You can update to the latest version via Help & Info → Update inside SweepMe! or download it from our homepage:
Download SweepMe!
As always, we appreciate your feedback!
Happy Measuring!
— The SweepMe! Team
