Hi
I’ve been trying to implement the Keithley 4200 Lib that you have all developed into some scripts i can use for some measurements. (see below)
I’ve managed to get simple scripts working both single and dual channel but python is just to slow to run some and custom waveforms are required. I’ve been trying to run the Seg_arb function collecting data at specific sections.
Using examples in the LPT manual i can get it to work up until the point i need to take data and it just doesn’t let me and fails every time. (when you set measurement type too any value other than 0) see below:
num_segments = 7
sequence_number = 1
seg_start_v = [0, 1, 1, 1.5, 1.5, 0, 0]
seg_stop_v = [1, 1, 1.5, 1.5, 0, 0, 0]
# Times
seg_times = [50e-9, 100e-9, 20e-9, 150e-9, 50e-9, 500e-9, 130e-9] # 10µs, 1µs, 10µs
# Trigger (first segment = 1)
seg_trig_out = [1, 1, 1, 0, 0, 0, 0]
# SSR Control (1 = output enabled)
ssr_ctrl = [1, 1, 1, 1, 1, 1, 0]
# Measurement - try enabling spot mean (type=1) in specific segments
meas_type = [0, 0, 0, 0, 0, 0, 0] # Measure in segments 1 and 3
meas_start = [0, 25e-9, 0, 50e-9, 0, 0, 0] # Start 25ns into segment
meas_stop = [0, 75e-9, 0, 100e-9, 0, 0, 0] # Stop 75ns into segment
when anything other than 0 is used within meas_type i get the following error:
[ERROR] seg_arb_sequence failed: Server-side processing failed with K4200Error(‘Illegal value for parameter #%d.’)
I thought maybe it was due to having to define some peramiters before hand but I am also following a c example that works and dosnt have this but still cannot seemingly get it to work correctly, any idea why?
Any help would be greatly appreciated, current script below:
Craig
import sys from pathlib import Path import time # Add project root to path sys.path.insert(0, str(Path(__file__).resolve().parents[3])) from ProxyClass import Proxy def test_simple_segarb(): """Minimal segment ARB test.""" # Connect print("Connecting to PMU...") lpt = Proxy("192.168.0.10", 8888, "lpt") param = Proxy("192.168.0.10", 8888, "param") lpt.initialize() lpt.tstsel(1) lpt.devint() card_id = lpt.getinstid("PMU1") print(f"[OK] Connected, card_id = {card_id}\n") # Configuration channel = 1 v_range = 10.0 i_range = 0.0002 # Try 0.2A range instead of 0.01A (both are valid for 10V range) load_resistance = 1000.0 try: print("Configuring RPM...") lpt.rpm_config(card_id, channel, param.KI_RPM_PATHWAY, param.KI_RPM_PULSE) print() except Exception as e: print(f"{e}") try: print("Initializing Segment ARB mode...") # Try using param.PULSE_MODE_SARB instead of hardcoded 2 try: PULSE_MODE_SARB = param.PULSE_MODE_SARB print(f" Using param.PULSE_MODE_SARB = {PULSE_MODE_SARB}") except: PULSE_MODE_SARB = 2 print(f" Using hardcoded PULSE_MODE_SARB = {PULSE_MODE_SARB}") lpt.pg2_init(card_id, PULSE_MODE_SARB) print() except Exception as e: print(f"{e}") return try: print("Setting limit mode to return actual values...") lpt.setmode(card_id, param.KI_LIM_MODE, param.KI_VALUE) print() except Exception as e: print(f" [ERROR] setmode failed: {e}") return try: print(f"Setting load resistance = {load_resistance} Ohm...") lpt.pulse_load(card_id, 1, float(load_resistance)) print("OK Channel 1") lpt.pulse_load(card_id, 2, float(load_resistance)) print("OK Channel 2") except Exception as e: print(f"pulse_load failed: {e}") return # CRITICAL: Must set PMU ranges when using RPM mode to avoid SSR error! try: print(f"Setting PMU ranges for Channel {channel}: V={v_range}V, I={i_range}A...") # Use PULSE_MEAS_FIXED (=2) for fixed ranges lpt.pulse_ranges(card_id, channel, v_src_range=float(v_range), v_range_type=2, # param.PULSE_MEAS_FIXED v_range=float(v_range), i_range_type=2, # param.PULSE_MEAS_FIXED i_range=float(i_range)) print("PMU ranges set") except Exception as e: print(f"pulse_ranges failed: {e}") print(f"Parameters: card_id={card_id}, channel={channel}, v_range={v_range}, i_range={i_range}") return try: print(f"Setting sample rate = 10 MSa/s...") sample_rate = 10e6 lpt.pulse_sample_rate(card_id, int(sample_rate)) print() except Exception as e: print(f"pulse_sample_rate failed: {e}") return try: print(f"Setting burst count = 1...") lpt.pulse_burst_count(card_id, channel, 1) print() except Exception as e: print(f"pulse_burst_count failed: {e}") return # # Configure measurement (spot mean for Segment ARB) # try: # print(f"Configuring spot mean measurement...") # lpt.pulse_meas_sm( # card_id, channel, # acquire_type=0, # 0 = per-period (PULSE_MEAS_SMEAN_PER) # acquire_meas_v_ampl=1, # Measure voltage amplitude # acquire_meas_v_base=0, # Don't measure base # acquire_meas_i_ampl=1, # Measure current amplitude # acquire_meas_i_base=0, # Don't measure base # acquire_time_stamp=1, # Capture timestamps # llecomp=0 # No load-line compensation # ) # print("Spot mean configured") # except Exception as e: # print(f"pulse_meas_sm failed: {e}") # # Continue anyway - might not be needed # # Configure measurement timing window # try: # print(f"Configuring measurement timing...") # lpt.pulse_meas_timing( # card_id, channel, # 0.1, # Start at 10% into segment # 0.9, # Stop at 90% into segment # 1 # Number of pulses # ) # print("Measurement timing configured") # except Exception as e: # print(f"pulse_meas_timing failed: {e}") # # Continue anyway # Define simple 3-segment waveform print("\n Defining segment ARB sequence...") num_segments = 7 sequence_number = 1 seg_start_v = [0, 1, 1, 1.5, 1.5, 0, 0] seg_stop_v = [1, 1, 1.5, 1.5, 0, 0, 0] # Times seg_times = [50e-9, 100e-9, 20e-9, 150e-9, 50e-9, 500e-9, 130e-9] # 10µs, 1µs, 10µs # Trigger (first segment = 1) seg_trig_out = [1, 1, 1, 0, 0, 0, 0] # SSR Control (1 = output enabled) ssr_ctrl = [1, 1, 1, 1, 1, 1, 0] # Measurement meas_type = [0, 2, 0, 0, 0, 0, 0] meas_start = [0, 25e-9, 0, 50e-9, 0, 0, 0] # Start 25ns into segment meas_stop = [0, 75e-9, 0, 100e-9, 0, 0, 0] # Stop 75ns into segment print(f" Voltages: {seg_start_v}") print(f" Times: {seg_times}") print(f" Trig out: {seg_trig_out}") print(f" SSR ctrl: {ssr_ctrl}") print(f" Meas type: {meas_type}") try: lpt.seg_arb_sequence( card_id, channel, sequence_number, num_segments, seg_start_v, seg_stop_v, seg_times, seg_trig_out, ssr_ctrl, meas_type, meas_start, meas_stop ) print(" [OK] seg_arb_sequence succeeded!") print() except Exception as e: print(f" seg_arb_sequence failed: {e}") print(f"Debug info:") print(f"card_id = {card_id}") print(f"channel = {channel}") print(f"sequence_number = {sequence_number}") print(f"num_segments = {num_segments}") print(f"seg_start_v = {seg_start_v}") print(f"seg_stop_v = {seg_stop_v}") print(f"seg_times = {seg_times}") return try: print("Programming waveform...") seq_list = [1] loop_count = [1.0] # Use float for loop count lpt.seg_arb_waveform(card_id, channel, 1, seq_list, loop_count) print(" [OK] seg_arb_waveform succeeded!") except Exception as e: print(f"seg_arb_waveform failed: {e}") return # Execute print("Executing waveform...") try: lpt.pulse_output(card_id, channel, 1) print("Output enabled") lpt.pulse_exec(param.PULSE_MODE_SIMPLE) print("Pulse executing...") # Wait for completion while True: status, elapsed = lpt.pulse_exec_status() if status != param.PMU_TEST_STATUS_RUNNING: break time.sleep(0.01) print("Execution complete!") except Exception as e: print(f"Execution failed: {e}") print() print(" returning waveform data...") # time start for data is 10e-6+1e-6 = 11e-6 # time end for data is 11e-6 + 50e-6 = 61e-6 # sample rate is 10e6 # so we need to fetch data from 11e-6 to 61e-6 # still to do total_time = sum(seg_times) expected_samples = int(total_time * sample_rate) print("total_time: ", total_time) print("expected_samples: ", expected_samples) buf_size = lpt.pulse_chan_status(card_id, channel) print("buf_size: ", buf_size) v_data, i_data, ts_data, st_data = lpt.pulse_fetch(card_id, channel,0,10) print("v_data: ", v_data) print("i_data: ", i_data) print("clean_up...") # Cleanup try: lpt.pulse_output(card_id, channel, 0) print(" Output disabled") except: pass if __name__ == "__main__": test_simple_segarb()
