SweepMe does not remember baud rate changes
Hi there,
SweepMe does not remember the change of the baud rate for a COM port in the port manager. This must be adjusted manually when SweepMe is restarted.
Currently this applies to version 1.5.6.24. In our case SweepMe was installed under a user account. Possibly this may not be the case if SweepMe is installed under an admin account. In version 1.5.5 SweepMe remembered the change of baud rate,
but here SweepMe was installed as admin. Does SweepMe not remember the baud rate change because it was installed under a user account?
Translated with DeepL.com (free version)
Hello Steffen,
thanks for reporting the issue! I was able to reproduce the bug. The configuration is saved to your setting.set file if you save the setting after changing the port properties via the port manager. However, it seems that the changes are not applied correctly after a restart of SweepMe! and reloading the setting. We will look into the issue and update you here.
Hello Steffen,
We have resolved the issue where manually set port properties were not correctly loaded when opening a setting. This fix has been implemented in Version 1.5.6.27.
Hello Franz,
thank you very much, we will test it with the next version.
Steffen
