PID values in custom function
the values of the PID module (PID_stable, PID_in_range and PID_stable_change) are passed as numpy.float64 when transferred to a custom function, whereby they are boolen values or an int value (PID_stable_change). This occurs in version 1.5.6, in version 1.5.5 it still works. It is possible to convert the values to boolean, but this is not the solution.
Best regards,
Steffen
Hello Steffen,
thanks for reporting the issue. We will check what is going on.
In the meantime, I think adding a bool conversion to your custom function is a workaround that works with both versions and makes sure you have correct data type. The values for PID_stable, PID_in_range and PID_stable_change should still be always 0.0 or 1.0 and allow for a proper conversion.
Your problem is probably related to how some data types are saved in the data manager of SweepMe! in version 1.5.6, a problem related to this issue
