New Feature: Set up configurations with the ReadValues Module
The ReadValues module now updates the Parameter System even before starting the measurement sequence. This enhancement significantly expands the module’s capabilities, allowing you to set up the sweep editor and module settings based on the first line of read values from external sources such as .xlsx, .txt, or .ini files. With this, you can set up configuration files for different measurement routines.
Setting Sweep values
ReadValues
Setting Driver parameters
Similarly, you can set Module and Driver parameters using the Parameter System.
Example Use Cases
  • Measurement Ranges: Define different Sweep ranges for CV curves for different sets of samples.
  • Read out pin selection: Dynamically choose which pins to readout for multiple setups.
  • Parameter Adjustments: Easily adjust parameters for different runs by swapping between your external configuration files.
Getting Started
To start using this feature, ensure you have a licensed version of SweepMe! installed. Go to Tools - Modules & Devices and update the ReadValues module to the newest version (2024-06-28). Refer to the wiki page for detailed instructions on how to set up and use the ReadValues module.
As always, we welcome your feedback and look forward to hearing about your experiences with this new capability.
Happy Measuring!
