New Feature: Copy & Paste in the Sequencer!
Weβre excited to introduce Copy & Paste functionality in the SweepMe! Sequencer! ![]()
You can now duplicate sequencer elements easily using either:
- The right-click context menu
- The Ctrl+C / Ctrl+V keyboard shortcuts
How It Works
Uses
- Need a driver, module, or sequence twice? β Just copy it!
- Want to share sequencer parts between different settings? β Copy the desired elements, open another setting or a second instance of SweepMe!, and paste them!
Copy Data is JSON Formatted
- Easily share sequencer parts with other users!
- Import shared sequences from the forum into your own settings.
- Edit sequences in your favorite text editor and copy them back into SweepMe!
Limitations
- Some modules like Robot and Form are not fully integrated yet. They can be copied, but their module-specific parameters wonβt transfer (yet!).
Try It Yourself!
Copy the JSON snippet below and paste it into SweepMe! to see the new feature in action:
"module_type": "Delay",
"Label": "Delay",
"value": "1",
"module_type": "Calc",
"Label": "Countdown",
"Variable": "Parameter",
"Unit": "a.u.",
"Function": "10 - x1",
"Plot": true,
"Save": true,
"Execution": "Always",
"Value1": "Sweep index of Loop",
"Value2": "",
"Value3": "",
"Label": "Flux Capacitor",
"Device": "SMU-Simulation_Diode",
"Channel": "",
"Port": "",
"RouteOut": "Front",
"Compliance": "0.001",
"Speed": "Fast",
"RangeVoltage": "Auto",
"Average": 1,
"PulseOffLevel": "0",
"PulseOnTime": "200e-6",
"PulsePeriod": "1e-3",
"PulseDelay": "0.0",
"PulseMeasTime": 30,
"PulseRiseTime": "100e-9",
"PulseFallTime": "100e-9",
"PulseImpedance": "200e-3",
"start": "0.0",
"end": "0.0",
"ListSweepCheck": true,
"ListSweepStart": "0.5",
"ListSweepDelaytime": "0.1",
"Label": "Loop",
"value": "10",
"Repetitions": "10",
