Added Simulation Drivers
We have added drivers that simulate connected devices and generate data for instrument modules. These can be used for various purposes, including:
  • Testing settings without real hardware
  • Trying out logics and branches in workflows
  • Demonstration for presentations or training
  • Debugging and troubleshooting module behavior
  • Developing custom drivers by using a simulation driver as template
Available Simulation Drivers
The following simulation drivers are now available:
  • :electric_plug: Logger-Simulation_MultiMeter – Simulates current (I) and voltage (V) channels.
  • :level_slider: Switch-Simulation_Driver – Allows setting a voltage and returning the set voltage.
  • :light_bulb: SMU-Simulation_Diode – Simulates an IV diode measurement.
  • :straight_ruler: LCRmeter-Simulation_Driver – Simulates resistance and reactance for module post-processing.
  • :robot: WaferProber-Simulation_Driver – Loads a pre-determined probe plan and runs the plan.
  • :thermometer: Temperature-Simulation_Driver – Simulates a temperature sensor by setting and returning temperature values.
  • :antenna_bars: Signal-Simulation_Driver – Generates signals of different types (sine, rectangular, …) and parameters (frequency, phase, …).
  • :chart_decreasing: Scope-Simulation_Driver – Displays either a sine/cosine signal or a signal generated by the Signal-Simulation_Driver.
  • :flashlight: Spectrometer-Simulation_Driver – Simulates different measured spectra: background, Raman spectrum, diode. Choose different ports to vary the spectrum.
  • :spider_web: NetworkAnalyzer-Simulation_Driver – Returns a sine signal for testing for different configurations.
  • :chart_increasing: SpectrumAnalyzer-Simulation_Driver – For future use with the new SpectrumAnalyzer module.
How to Get the Simulation Drivers
You can download these drivers via the Version Manager in Tools → Modules & Devices
Also, be sure to check out the example settings to see how they can be used in practice!
Happy Simulating!
— The SweepMe! Team
