MBRAUN Evaporation Systems Are Ready for SweepMe!: Automate Your Vacuum Deposition
If you work with a vacuum chamber for thermal evaporation or other deposition processes, you probably know the picture: the vacuum gauge, the temperature controllers of the sources, the quartz crystal monitor and the shutters each come with their own display, and the process itself lives in a lab notebook. SweepMe! brings all of these instruments into one interface, so you can log, control and finally automate your process in one place.
We are happy to announce our partnership with MBRAUN.
MBRAUN is widely known for its gloveboxes, but it also builds vacuum evaporation and deposition systems, and these are prepared for fast process control automation through the SweepMe! platform.
Choose your level of integration
You decide how far the automation goes. Most labs start small and add more control step by step:
  • Monitoring: Log and visualize all manually controlled instruments. You keep operating the chamber the way you are used to, while SweepMe! records pressure, temperatures, deposition rates and thicknesses side by side and shows them live on the Dashboard.
  • Semi-automatic control: Control the layer deposition process in the software. For example, set the source temperatures and open or close the shutters from SweepMe!, while you still decide when each layer starts.
  • Full automation: Run multilayer co-deposition fully automatically from a recipe, so the same layer stack is deposited the same way every time.
Further below, you will find an example sequence for each level.
Drivers for MBRAUN chambers are ready
Drivers for the typical components of an MBRAUN chamber, such as temperature controllers, pressure sensors, QCM monitors and shutters, are readily available. One example is the driver for the MBRAUN SCU 101 Shutter Control Unit: it talks Modbus via RS-232 or RS-485, controls shutter 1 or 2, reports states such as open, closed or moving, and can put the shutter into a defined state at the start and at the end of a run. Additional instruments or replacement parts can be integrated at any time.
Our one-pager on evaporation control with SweepMe! sums up the options, and MBRAUN presents its vacuum coating systems on its website.
Not using an MBRAUN system?
The same approach works for any vacuum chamber whose instruments SweepMe! can talk to. The driver library already includes, among others:
  • Vacuum gauges and controllers: Pfeiffer Vacuum TPG 251 A, 252 A, 256 A, 361, 362 and 366, Leybold Combivac CM31, JEVATEC JEVAmet VCU and VCU active
  • Thickness and rate monitors: Inficon SQM-160, IC/5, XTM/2, STM-2XM and SQC-310C (read out as a rate monitor)
  • Temperature controllers: Eurotherm 22xx, 24xx, 32xx and 350x series, JUMO diraTRON
  • Shutters: MBRAUN SCU 101, PREVAC TMC13 used as shutter control unit
  • Mass flow controllers: Bronkhorst EL-FLOW, ES-FLOW and other devices with the Propar protocol
If your chamber is run by a PLC, the PLC Module, one of our Special Modules, connects SweepMe! to it via Modbus TCP. And if an instrument is still missing, let us know: many drivers in the library started as a request from a single lab. You find all drivers on our website.
Example: one evaporation chamber, three levels of automation
To show how the three levels look in practice, we prepared one sequence for each of them. They are set up for a typical thermal evaporation chamber with two sources:
  • Pressure: Pfeiffer Vacuum TPG 362 at COM3, channel 1 named “Chamber”
  • Rate and thickness: Inficon SQC-310C at COM4, sensor 1 for source A and sensor 2 for source B
  • Source temperatures: two Eurotherm 32xx controllers for source A and source B on one RS-485 line at COM5, with the Modbus addresses 1 and 2
  • Shutters: MBRAUN SCU 101 at COM6, shutter 1 for source A and shutter 2 for source B
If your chamber uses other instruments, select their drivers in the field “Device” of the respective module. The structure of the sequences stays the same. Just check the variable names used in the Condition modules and whether your QCM driver can reset the thickness.
Image: Sequencer for the semi-automatic control
To get started:
  1. Download SweepMe!: sweep-me.net/download_sweepme
  2. Install the drivers: Go to menu “Tools” → “Version Manager” and type “TPG, SQC-310C, Eurotherm_32xx, SCU101” into the Device search bar, which lists all four drivers at once. Select each driver in the left list and activate a version. Modules that are not installed yet, such as ControlWidgets or Condition, can be installed there as well.
  3. Copy one of the snippets below and paste it into an empty Sequencer via right-click → “Paste” or Ctrl+V.
  4. Open each module and select your COM port. For the Eurotherm controllers, type the port together with the Modbus address, e.g. “COM5:1”.
  5. Start the run.
Level 1: Monitoring
The first sequence only reads values and never changes anything at the chamber. A MakeFile module saves all data to a text file. A Loop module in nonstop mode repeats the measurement until you press Stop, and a Delay module of 1 s sets the logging interval. Below the Delay module, there are a Logger module “Gauge” for the pressure, a Logger module “QCM” for thickness, rate and crystal life of both sensors, one Temperature module per source and one Switch module per shutter.
The Temperature and Switch modules use the sweep mode “None”. In addition, “Zero power afterwards” is unchecked, the shutter states at start and end are “As is”, and “Reset thickness” of the QCM is off. So SweepMe! never sends a setpoint, a shutter command or a thickness reset, and stopping the run leaves the chamber exactly as it is. It only uses free modules in a single branch, so this sequence runs with the free version of SweepMe!.
Snippet for level 1: Monitoring:
{"child_items": [
 {"module_details": {"module_type": "MakeFile", "Label": "MakeFile", "value": "Evaporation", "FileID": "Evaporation"}, "is_checked": true, "is_expanded": true, "child_items": [
  {"module_details": {"module_type": "Loop", "Label": "Loop", "value": "nonstop", "Repetitions": "0"}, "is_checked": true, "is_expanded": true, "child_items": [
   {"module_details": {"module_type": "Delay", "Label": "Delay", "value": "1"}, "is_checked": true, "is_expanded": true, "child_items": [
    {"module_details": {"module_type": "Logger", "Label": "Gauge", "value": "", "Device": "Logger-PfeifferVacuum_TPGxxx", "Port": "COM3", "Parameters": {"Use Channel 1": true, "Channel 1": "Chamber"}}, "is_checked": true, "is_expanded": true, "child_items": [
     {"module_details": {"module_type": "Logger", "Label": "QCM", "value": "", "Device": "Logger-Inficon_SQC-310C", "Port": "COM4", "Parameters": {"Reset thickness": false, "Sensor1": true, "Sensor2": true}}, "is_checked": true, "is_expanded": true, "child_items": [
      {"module_details": {"module_type": "Temperature", "Label": "Source A", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:1", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": false, "ZeroPowerAfterSweep": false, "SweepMode": "None", "SweepValue": "SweepBox"}, "is_checked": true, "is_expanded": true, "child_items": [
       {"module_details": {"module_type": "Temperature", "Label": "Source B", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:2", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": false, "ZeroPowerAfterSweep": false, "SweepMode": "None", "SweepValue": "SweepBox"}, "is_checked": true, "is_expanded": true, "child_items": [
        {"module_details": {"module_type": "Switch", "Label": "Shutter A", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "None", "Parameters": {"Modbus address": "1", "Shutter number": "1", "State at start": "As is", "State at end": "As is"}}, "is_checked": true, "is_expanded": true, "child_items": [
         {"module_details": {"module_type": "Switch", "Label": "Shutter B", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "None", "Parameters": {"Modbus address": "1", "Shutter number": "2", "State at start": "As is", "State at end": "As is"}}, "is_checked": true, "is_expanded": true, "child_items": []}
"version": "v1",
"sweepme_version": "1.6.1.7"
Level 2: Semi-automatic control
The second sequence adds a ControlWidgets module at the top. It places two sliders, “Heater A” and “Heater B”, and a button box “Shutters” with one toggle button per shutter on the Dashboard. The Temperature modules now use the sweep mode “Temperature” and take their setpoint from the sliders (sweep value “Controls Heater A Setpoint in °C”). The Switch modules use the sweep mode “State” and take the shutter state from the toggle buttons (sweep value “Controls Shutters Shutter A”), which return “closed” or “open”. Every change is applied at the next measurement point, while pressure, temperatures, rates and thicknesses keep being logged.
This way, you decide when a layer starts and ends while you watch rate and thickness live. “Reach Temperature” is unchecked, so logging continues while a source ramps. The sliders are limited to 20 to 400 °C. Whenever you start the run, they are set to 25 °C (field “Initial”) and both shutters are closed (“State at start”: “Closed”), so the sources only heat up and the shutters only open when you say so. Keep this in mind before you restart the run in the middle of a layer. When you stop the run, “Zero power afterwards” switches off both sources and the shutters close (“State at end”: “Closed”).
Snippet for level 2: Semi-automatic control
{"child_items": [
  {"module_details": {"module_type": "ControlWidgets", "Label": "Controls", "value": "", "widgets": [{"Type": "Slider", "Title": "Heater A", "Value": "25", "LimitUpper": "400", "LimitLower": "20", "Variable": "Setpoint in °C", "Initial": "25", "Unit": ""}, {"Type": "Slider", "Title": "Heater B", "Value": "25", "LimitUpper": "400", "LimitLower": "20", "Variable": "Setpoint in °C", "Initial": "25", "Unit": ""}, {"Type": "ButtonBox", "Title": "Shutters", "Alignment": "Left to right", "Button1": "DoubleToggleButton", "Button1_Variable": "Shutter A", "Button1_Label1": "A closed", "Button1_Label2": "A open", "Button1_Value1": "closed", "Button1_Value2": "open", "Button2": "DoubleToggleButton", "Button2_Variable": "Shutter B", "Button2_Label1": "B closed", "Button2_Label2": "B open", "Button2_Value1": "closed", "Button2_Value2": "open"}]}, "is_checked": true, "is_expanded": true, "child_items": [
       {"module_details": {"module_type": "Temperature", "Label": "Source A", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:1", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": false, "ZeroPowerAfterSweep": true, "SweepMode": "Temperature", "SweepValue": "Controls Heater A Setpoint in °C"}, "is_checked": true, "is_expanded": true, "child_items": [
        {"module_details": {"module_type": "Temperature", "Label": "Source B", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:2", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": false, "ZeroPowerAfterSweep": true, "SweepMode": "Temperature", "SweepValue": "Controls Heater B Setpoint in °C"}, "is_checked": true, "is_expanded": true, "child_items": [
         {"module_details": {"module_type": "Switch", "Label": "Shutter A", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "Controls Shutters Shutter A", "SweepMode": "State", "Parameters": {"Modbus address": "1", "Shutter number": "1", "State at start": "Closed", "State at end": "Closed"}}, "is_checked": true, "is_expanded": true, "child_items": [
          {"module_details": {"module_type": "Switch", "Label": "Shutter B", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "Controls Shutters Shutter B", "SweepMode": "State", "Parameters": {"Modbus address": "1", "Shutter number": "2", "State at start": "Closed", "State at end": "Closed"}}, "is_checked": true, "is_expanded": true, "child_items": []}
"version": "v1",
Level 3: Full automation from a recipe
The third sequence deposits a layer stack on its own: 20 nm from source A, followed by 30 nm from source A co-deposited with source B. Right below the MakeFile module, two Switch modules “Shutter A” and “Shutter B” close both shutters when the run starts and record their states, and the Logger module “Gauge” records the pressure. As these three modules are part of every branch, their values are saved at every measurement point of the run. Below them, each layer is built from the same blocks:
  • Temperature modules with the setpoints of the layer in the SweepBox, e.g. 180 °C. “Reach Temperature” makes SweepMe! wait until each source has stayed within ±1 °C (“Accuracy range”) for 60 s (“Hold accuracy range”).
  • A heat-up branch with a Hold module that waits another 60 s once the setpoints are reached.
  • A deposition branch, in which Switch modules open the shutters (SweepBox “open”, any other text closes them) and a nonstop Loop with a Delay of 1 s reads the QCM of this layer. “Reset thickness” is checked, so each layer starts at 0 nm.
  • A Condition module at the end of the deposition branch. Its condition “Thickness” compares {Layer_1_QCM_Thickness1_nm} with the target after each point and calls skip_current_branch as soon as the target is reached. In layer 2, it checks sensor 1, so the layer ends after 30 nm of material A. To stop at the total thickness instead, enter {Layer_2_QCM_Thickness1_nm} + {Layer_2_QCM_Thickness2_nm} as variable. A second condition “Timeout” stops the run after 3600 points, about one hour, in case the target is never reached.
Why a separate heat-up branch? Within one branch, SweepMe! first applies all new values and only then waits until they are reached. If the shutters were in the same branch as the sources, they would open while the sources are still heating up. With the heat-up in its own branch, the shutters open only once the sources are stable.
When a layer is done, its shutters close (“State at end”: “Closed”) and its sources are switched off (“Zero power afterwards”). If the next layer uses the same source, its own Temperature module switches the source on again right away. The same happens when you stop the run: the shutters close and the sources go to zero power. To keep a source warm between layers instead, uncheck “Zero power afterwards” and enter an “Idle temperature”. Note that the source then also stays at this temperature after the run.
To add a layer, copy a layer branch and paste it while the module “Gauge” is selected, so that it is added as the last layer. SweepMe! appends " - Copy" to labels that are already taken, so rename the new modules and adjust setpoints and target. Then update both variables in the new Condition module, as they refer to the labels of the QCM Logger and of the Loop. Each branch is saved to its own data file: the heat-up branch adds a single line with the values right before the shutters open, and the deposition branch logs the complete layer.
Snippet for level 3: Full automation
{"child_items": [
 {"module_details": {"module_type": "MakeFile", "Label": "MakeFile", "value": "Deposition", "FileID": "Deposition"}, "is_checked": true, "is_expanded": true, "child_items": [
  {"module_details": {"module_type": "Switch", "Label": "Shutter A", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "None", "Parameters": {"Modbus address": "1", "Shutter number": "1", "State at start": "Closed", "State at end": "Closed"}}, "is_checked": true, "is_expanded": true, "child_items": [
   {"module_details": {"module_type": "Switch", "Label": "Shutter B", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "None", "Parameters": {"Modbus address": "1", "Shutter number": "2", "State at start": "Closed", "State at end": "Closed"}}, "is_checked": true, "is_expanded": true, "child_items": [
     {"module_details": {"module_type": "Temperature", "Label": "Layer 1 Source A", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:1", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": true, "Accuracy": "1", "HoldAccuracy": "60", "ZeroPowerAfterSweep": true, "SweepMode": "Temperature", "SweepValue": "SweepBox", "SweepBox": {"sweep_values": "180"}}, "is_checked": true, "is_expanded": true, "child_items": [
      {"module_details": {"module_type": "Hold", "Label": "Hold", "value": "60"}, "is_checked": true, "is_expanded": true, "child_items": []},
      {"module_details": {"module_type": "Switch", "Label": "Layer 1 Shutter A", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "State", "Parameters": {"Modbus address": "1", "Shutter number": "1", "State at start": "Closed", "State at end": "Closed"}, "SweepBox": {"sweep_values": "open"}}, "is_checked": true, "is_expanded": true, "child_items": [
       {"module_details": {"module_type": "Loop", "Label": "Layer 1 Deposition", "value": "nonstop", "Repetitions": "0"}, "is_checked": true, "is_expanded": true, "child_items": [
         {"module_details": {"module_type": "Logger", "Label": "Layer 1 QCM", "value": "", "Device": "Logger-Inficon_SQC-310C", "Port": "COM4", "Parameters": {"Reset thickness": true, "Sensor1": true}}, "is_checked": true, "is_expanded": true, "child_items": [
          {"module_details": {"module_type": "Condition", "Label": "Layer 1 Thickness", "value": "", "conditions": [{"Label": "Thickness", "Execution": "After each point (in 'finish')", "Variable": "{Layer_1_QCM_Thickness1_nm}", "Relation": ">=", "Value": "20", "ActionIf": ["skip_current_branch"], "ActionElse": [], "Notes": "Ends layer 1 when the target thickness in nm is reached."}, {"Label": "Timeout", "Execution": "After each point (in 'finish')", "Variable": "{Layer_1_Deposition_Index}", "Relation": ">=", "Value": "3600", "ActionIf": ["stop"], "ActionElse": [], "Notes": "Safety stop if the target is not reached within 3600 points (about 1 h with a 1 s delay)."}]}, "is_checked": true, "is_expanded": true, "child_items": []}
     {"module_details": {"module_type": "Temperature", "Label": "Layer 2 Source A", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:1", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": true, "Accuracy": "1", "HoldAccuracy": "60", "ZeroPowerAfterSweep": true, "SweepMode": "Temperature", "SweepValue": "SweepBox", "SweepBox": {"sweep_values": "180"}}, "is_checked": true, "is_expanded": true, "child_items": [
      {"module_details": {"module_type": "Temperature", "Label": "Layer 2 Source B", "value": "", "Device": "Temperature-Eurotherm_32xx", "Channel": "1", "Port": "COM5:2", "TemperatureUnit": "°C", "MeasureT": true, "ReachT": true, "Accuracy": "1", "HoldAccuracy": "60", "ZeroPowerAfterSweep": true, "SweepMode": "Temperature", "SweepValue": "SweepBox", "SweepBox": {"sweep_values": "150"}}, "is_checked": true, "is_expanded": true, "child_items": [
       {"module_details": {"module_type": "Switch", "Label": "Layer 2 Shutter A", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "State", "Parameters": {"Modbus address": "1", "Shutter number": "1", "State at start": "Closed", "State at end": "Closed"}, "SweepBox": {"sweep_values": "open"}}, "is_checked": true, "is_expanded": true, "child_items": [
        {"module_details": {"module_type": "Switch", "Label": "Layer 2 Shutter B", "value": "", "Device": "Switch-MBRAUN_SCU101", "Port": "COM6", "SweepValue": "SweepBox", "SweepMode": "State", "Parameters": {"Modbus address": "1", "Shutter number": "2", "State at start": "Closed", "State at end": "Closed"}, "SweepBox": {"sweep_values": "open"}}, "is_checked": true, "is_expanded": true, "child_items": [
         {"module_details": {"module_type": "Loop", "Label": "Layer 2 Deposition", "value": "nonstop", "Repetitions": "0"}, "is_checked": true, "is_expanded": true, "child_items": [
           {"module_details": {"module_type": "Logger", "Label": "Layer 2 QCM", "value": "", "Device": "Logger-Inficon_SQC-310C", "Port": "COM4", "Parameters": {"Reset thickness": true, "Sensor1": true, "Sensor2": true}}, "is_checked": true, "is_expanded": true, "child_items": [
            {"module_details": {"module_type": "Condition", "Label": "Layer 2 Thickness", "value": "", "conditions": [{"Label": "Thickness", "Execution": "After each point (in 'finish')", "Variable": "{Layer_2_QCM_Thickness1_nm}", "Relation": ">=", "Value": "30", "ActionIf": ["skip_current_branch"], "ActionElse": [], "Notes": "Ends layer 2 when the target thickness in nm is reached."}, {"Label": "Timeout", "Execution": "After each point (in 'finish')", "Variable": "{Layer_2_Deposition_Index}", "Relation": ">=", "Value": "3600", "ActionIf": ["stop"], "ActionElse": [], "Notes": "Safety stop if the target is not reached within 3600 points (about 1 h with a 1 s delay)."}]}, "is_checked": true, "is_expanded": true, "child_items": []}
"version": "v1",
All three sequences are also attached as files:
After download, load them via menu “Sequences” → “Load Sequence”.
A few notes before your first run:
  • All setpoints, thickness targets and times are example values. Adjust them to your materials and your chamber.
  • Material parameters such as density, Z-factor and tooling stay set on the SQC-310C. The driver reads thickness, rate and crystal life.
  • For more sources or shutters, add further Temperature and Switch modules. Each SCU 101 controls up to two shutters, selected with the parameter “Shutter number”.
Why one software for the whole chamber?
With all instruments in one sequence, you no longer copy pressures and rates from displays into your notebook. Every run is saved with all values and instrument settings, so you can compare layers across runs and repeat a process months later. And because the integration grows with you, you can start with free monitoring today and add automation when your process needs it.
Image: Screenshot of active rate control at an evaporation chamber
Let’s talk about your chamber
Whether you want to log an existing chamber or automate a complete multilayer process, we are happy to help. Reply to this topic with the chamber and instruments you use, or get in touch with us directly. If you prefer, we can also set up the automation for you as a system integration project, from missing drivers to the finished procedure in your lab.
:backhand_index_pointing_right: Contact us for details on automation options.
